Георгич написав:И это все?
Не читая нашел что у всех есть. Список даже не читая можно найти в тексте
https://en.wikipedia.org/wiki/Straight-three_engine
- Basic versions of the Suzuki Swift
- Opel Corsa, and later on the Suzuki Splash and the fifth generation of the Opel Corsa.
- Some Daihatsu cars use straight-three engines
- The Volkswagen Group is known for using three-cylinder petrol and diesel engines, in the Audi A2, Volkswagen Polo Volkswagen Up!, Volkswagen Fox, Volkswagen Lupo,
- SEAT Ibiza, SEAT Córdoba, SEAT Mii,
- Škoda Citigo and Škoda Fabia.
- Subaru used a straight-three engine in the Subaru Justy,[6] and the export version of the Subaru Sambar, called the Subaru Sumo, which had their Subaru EF engine.
- Mitsubishi has made extensive use of three-cylinder engines, which have also been used in the Smart ForTwo, since 2004 on the Mitsubishi Colt,[16] and from 2012 on the Mitsubishi Mirage.[17] A three-cylinder diesel engine was also used on the Mitsubishi Colt and the Smart Forfour.
- Nissan has developed a 1.2-litre three-cylinder version of their HR series of petrol engines, which is used since 2010 for the Nissan Micra, the Nissan Almera (Thailand) and the Nissan Note. There is also a supercharged version, with direct injection and variable valve timing.[18]
- The Hyundai Motor Group used a 1.5-litre three-cylinder diesel engine (developed by VM Motori) on the second generation of the Hyundai Accent, the Hyundai Getz and the Hyundai Matrix, and developed its own 1.1-litre three-cylinder diesel engine (part of their U-Line), which has been used in the Kia Picanto and the Hyundai i10. Another 1.0-litre three-cylinder petrol engine (part of the Kappa series) has been used in the Hyundai i10 and the Hyundai HB20.
- Ford started offering their new turbocharged 1.0-litre three-cylinder EcoBoost unit in the Focus from 2012,
- In September 2012, Renault introduced a new turbocharged 0.9-liter TCe engine,
- In October 2013, the PSA Peugeot Citroën group inaugurated the production line of their new turbocharged three-cylinder 1.2-litre petrol engine, in Douvrin, France.
- Starting from 2014, the Opel Adam will be offered with a new turbocharged three-cylinder engine, mated to a six-speed manual gearbox.[26] This engine, branded SIDI (Spark Ignition Direct Injection), uses direct injection, continuously variable valve timing and has a lightweight aluminium cylinder block.[27]
- The BMW B38 is a DOHC 1.5 litre 3 cylinder turbocharged petrol engine. The B38 is the first use of BMW's modular engine strategy for gasoline and diesel engines, all using the same bore spacing, and all producible on the same assembly line equipment. This engine was first used in the 2013 BMW i8 and 2014 Mini Hatch - replacing the previous four-cylinder engine in the Mini - and is intended for future front wheel drive BMW products.
Mazda CX-5, AWD, 2.5л, бенз
Спасибо сказали: ivalent, Георгич2
