1 Відредаговано igorsh88 (2025-10-12 09:10:37)
https://logan.in.ua/upload/iblock/2f9/2dkg3r1btdu7zxmu0epx4c22zdy1aohv/480_640.jpg https://logan.in.ua/upload/iblock/b46/2hlyvyygk7mg0nyk6tlb88hpo1auex6e/VAZ163-_1_.jpg  https://logan.in.ua/upload/iblock/858/51q4d6pd6mqoug6zq22rw4rua4xj3m2m/6400480-_1_.jpg https://logan.in.ua/upload/iblock/195/xo43rd2f45ae2t2vwh3k9fdvkyzv79oi/elektrosxemi_renault_logan_rul_600x800.jpg https://logan.in.ua/upload/iblock/6a1/c033nkp9y65qp6ng7dlypwk8xcydshmk/Bezymyannyy.jpg https://logan.in.ua/upload/iblock/c5c/kjj8o9vlqn1jy4frpa0megbmzqqsvlej/Remont_Largus_1.jpg https://logan.in.ua/upload/iblock/b25/9a2qt142flwvdr7wqixqmva8ns1yl4c4/IMG_20230519_210157-_1_.jpg https://logan.in.ua/upload/iblock/452/kwzpr98u0w17g8966120nvd65iqh0pj3/IMG_20230519_213929.jpg https://logan.in.ua/upload/iblock/881/sshfora44bhsvx3vnaoy0gmghvd8gjzd/IMG_20230914_172105.jpg https://logan.in.ua/upload/iblock/961/qq6q4gfoa10am2oiepcb7znodezl1bhk/IMG_20230925_162024.jpg   https://logan.in.ua/upload/iblock/4e9/gynrgsstp906kkdbylitn0i3gxdsda1m/imgonline_com_ua_Resize_ntSsg3czHQ.jpg https://logan.in.ua/upload/iblock/40e/6fhe9dhwrmyqlbj2ocfalpcduf9ek1fa/elektronne-kerivnitstvo.jpg https://logan.in.ua/upload/iblock/e5e/holph3yxjjs704kcfu5yl5teq6v5o5bb/IMG_20231031_072431.jpg https://logan.in.ua/upload/iblock/c53/bwr6mzwwcochmmo6e84t6d1t75soe9dk/IMG_20231031_072928.jpg https://logan.in.ua/upload/iblock/c39/309rj5xqpqm1ng6525p06nc7tpn2a1wq/imgonline_com_ua_Resize_sYYs767Im6V9i2.jpg   https://logan.in.ua/upload/iblock/930/8r9s7k21hob78t1s7e3stj43i1nencva/imgonline_com_ua_Resize_G48M7NWRo6.jpg   https://logan.in.ua/upload/iblock/529/5yotxcj2zw8aza3cqnrajnttz0y7fszd/imgonline_com_ua_Resize_AIL9k68nl0Dv8k.jpg   https://logan.in.ua/upload/iblock/689/5mtf37g2ttjmj540al3znyu2g4qzjhkm/imgonline_com_ua_Resize_ef9xKA6hPI20.jpg https://logan.in.ua/upload/iblock/1db/6jscetdf9w8vzzpzxlwuo8ijpjcuz3vr/Bez-imeni.jpg https://logan.in.ua/upload/iblock/972/knknql8kgeqaxcj2lr8rundtjidk02jn/16583055-_1_.jpeg https://logan.in.ua/upload/iblock/50e/21vm4v86bmt06gvu8dg0f2pmvbtpvy7y/imgonline_com_ua_Resize_kIxMxOj9jQZwpo.jpg
почав уходити антифриз, ~150мл/1000км
Якщо долили і все ОК, то скоріше за все повітря з системи вийшло.
Nissan QASHQAI 2.0 2021
От і думаю нормально то чи ні
Если подтёков нет, то вероятно вышел остаточный воздух из системы. За 1000 км 150 мл ни как не выпарится.
Может уходить по капле, не заметно.
Где тройник для Гбо
179 Відредаговано igorsh88 (2024-02-07 09:43:07)
КУДИ УХОДИТЬ АНТИФРИЗ, ПІДГОТОВКА
Долив 150 мл антифризу на 1000 км
Придбав саму дешеву кришку розширюючого бачка. Розібрав, просверлю отвір та вставлю вентиль, накачаю до 1 атм і шукатиму, де він може підтікати. Ідею взяв з цього відео
Кришка розширюючого бачка 03563 Metalcaucho
/upload/iblock/c8b/lxjuhhalatdig0mos4qjjg38k0pdpkj8/IMG_20230331_090713.jpg /upload/iblock/131/m6jff9siyygktktkhbut7iij697l2o2c/IMG_20230331_084535.jpg /upload/iblock/c3c/nfuj7ily6xhrrxi7g8hc6isqeo92o4ck/IMG_20230331_084451.jpg   /upload/iblock/6c8/mq048akezznlb24f2cjl6yur1b0olpkt/images-_1_.jpg
Раджу дивитись на штуцерах газового редуктора, я в себе на славуті постійно підтягував а вони продовжували сопливити, поставив по два хомути, патрубки фагуміт. Між редуктором і форсунками стояв семперіт, то в нього верхній шар виявився сирим, постійно підтягував хомути щоби газ не травив, потім таки довелось замінити на фагуміт.
igorsh88, идея не нова, но есть один минус -- исключается из поиска родная крышка расш.бачка. Я делаю так, снимаю верхний развоздуш.шланг, ставлю заглушку на его место в бачок, в снятый с бачка шланг подаю давление 1.4 бара (проверяю срабатывание клапана крышки бачка) и потом при давлении 1 бар проверяю систему на утечки. https://www.youtube.com/watch?v=b8aa6gUJhdo Тут у людей вообще все по взрослому, но важен сам принцип.
Також краще замінити черв'ячні хомути на пружинні, якщо вам поставили перші. В мене постійно підтікало, поки не поставив нормальні.
183 Відредаговано Migen (2023-03-31 23:21:43)
патрубки фагуміт
Поставьте шланги Parker и пружинные хомуты  и забудьте о подтекании навсегда
184 Відредаговано igorsh88 (2024-02-07 09:42:22)
КУДИ УХОДИТЬ АНТИФРИЗ, ПОШУК ПРОБЛЕМИ ЯКОЇ НЕМАЄ
Куди уходить антифриз? Підготовка
Що перевірив:
1. Кількість доливу антифризу на кожну 1000 км - явна динаміка до зменшення.
/upload/iblock/54c/xoyd5iwlxg053dyxwxkho69x20t51348/IMG_20230308_104612.jpg/upload/iblock/4e7/cqz251965ysp83hk10ablu0vzij7ra2r/IMG_20230328_081107.jpg/upload/iblock/46d/efuq3w8zcbdlr9l3n975ppnh2gqwn5rt/1681297554767.jpg
2. Працездатність клапана кришки бачка розширення охолоджуючої рідини - відкривається на ~1.1-1.3 Атм (по манометру від ручного насоса)
/upload/iblock/740/kx7c2xfcexpsego909vnrfe5d9p3hp1n/1681297715951.jpg/upload/iblock/5f5/6fp03f797emmhckfukx37ha8ubo8aozf/1681297715956.jpg
3. Опресовку системи охолодження - тиск тримає.
/upload/iblock/505/fbtwokfi847xpdpkjx3jbx7x5egi53za/IMG_20230404_114211.jpg/upload/iblock/c0b/qeed39rtp2bbtud13g2caexe7vynvcee/1681297715947.jpg/upload/iblock/4a1/cgrxqt05uemlh98u5zeh72e03d7y0gr2/IMG_20230404_130807.jpg/upload/iblock/c38/g8hppk4x2a6duv35uz83kqevt5wqqfaz/1681297715945.jpg
4. Тест на резиновий виріб номер два та резинову кульку - навіть не встав smile
/upload/iblock/f78/8zoy86626986xxshpmtxdd3xsnno02db/IMG_20230404_133214.jpg/upload/iblock/bc0/x45cvqvoo90ao1hs76f7fpkdd6qzw1b3/1681297715934.jpg
5. Візуально місця з'єднання штатних патрубків охолодження та редуктора ГБО - підтікань не виявив
6. Наявність в маслі антифризу - рівень масла стабільний, білого(жовтого) налету немає.
Висновки:
Просто повітря після заміни термостата ніяк не вийде, хоча й прошло 3000 км з того моменту
185 Відредаговано igorsh88 (2023-04-13 07:53:59)
ТРИМАЧ ТЕЛЕФОНА
Встановив магнітний тримач телефона в найбільш зручне місце
/upload/iblock/637/iv6s0ed9010nz17cys8bad5xt13hnyjc/1681297715930.jpg /upload/iblock/342/79yy6c5zzr76r8v6f0gnoirtu7mwp54k/1681297715932.jpg
ПЕРЕВЗУВСЯ НА ЛІТО
Літні шини Hankook 185/65/R15
Колісні болти почистив та змастив мідною смазкою
/upload/iblock/060/cjsupcemyyf9dku9x4vro9fguspfmyuf/IMG_20230401_183715.jpg /upload/iblock/7d7/jey5rh0fm3ni0yuqbtlzv14c0r45zapx/IMG_20230401_183654.jpg /upload/iblock/5b5/ojq3qopenvbgb2jmy4c1nzoxu8yw062v/IMG_20230401_183645.jpg /upload/iblock/26e/kzve8cxolo15ui5lu81gwmv2a2ymxmju/IMG_20230401_183800.jpg
Думаю, пофарбувати барабани   vissla
187 Відредаговано Лево (2023-04-13 09:58:59)
igorsh88, Викручуйте болти, вимивайте смазку. Не можна цього робити, є дуже цікаві відео з роз'ясненями що це може накоїти.
Лево написав:
в мануалі Субару про це прямо написано
189 Відредаговано igorsh88 (2023-04-13 11:05:47)
Це я вже проходив - прикипівші іржаві болти з гайками. Не перший рік мазюкаю всі елементи підвіски мідю і нічого не трапилось. Знаю, що є доводи за і проти, но я за. Трішки смазки не завадить.
190 Відредаговано igorsh88 (2023-04-14 15:58:47)
ІНДИКАТОР РІВНЯ ГАЗУ - КАЛІБРОВКА
Дістав мене цей індикатор, перші три лампочки тухли протягом перших 100 км, на останній решту 400 км їздив.
Зробив калібровку. Зафіксував показники датчика на пустому та повному балоні, а також при 10, 20, 30, 40 л газу в ньому.
Графік виявився не лінійним. Вніс зміни в програму налаштування, тепер все ок.
/upload/iblock/18a/4qadbjsokjqftj37079d9vx673lckk2y/grafik.jpg /upload/iblock/e87/sm3o9m7ecsnxacaa615em337hqdeuo2p/grafik2.jpg /upload/iblock/b84/9cmy71u4m9b6bumc31l1hmz6jos51ibh/IMG_1352.jpg
из-за наружного расположения газового баллона, на мультиклапан и датчик уровня попадает много влаги и защитный колпак не помогает. Собственно о чем, родной датчик уровня где то пол-года исправно работал, после пошли глюки и провалы. Калибровка не спасала, всему виной оказалась влага в разъёме датчика, а чуть позже и в самом датчике. Защитить разъём герметиком не получилось, периодическая смазка и зачистка контактов помогала на короткое время. Ну а когда влага попала внутрь датчика, не помогало уже ничего. Замена на бесконтактный ( эффект Холла) -- те же грабли с разъёмом, окисление и сбой, при очередной зачистке контактов, сломал ножку на датчике. На этом эпопея с датчиками закончилась, ориентируюсь по пробегу.
igorsh88, Мультіклапан BRC Europa 2?  якщо так - не допоможе)))  рідний датчик живе своїм життям, точність на нулі. Периодично міркую поставити стаговський, захищений.
Теж на мсв глючить датчик залишку газу.
Це болячка балонів, які на вулиці...
Забив і орієнтуюся по пробігу і витраті палива по бортовому.
А машина где ездит?
На одном работает,  а другой нет.
Похоже такое качество..
Тоже заправка по пробегу.
Пока не ошибся...
на тех что внутри тоже болячка , узел конструктивно не доработан , практически все жалуются  на разных авто и разние установки гбо
А машина где ездит?
Машина їздить по різних дорогах!(
На попередньому авто део сенс датчик рівня газу 8років справно служив і не глючив...
датчик рівня газу
В мене ніколи рівень газу нормально не показував.
198 Відредаговано igorsh88 (2024-02-07 09:41:17)
АНТИФРИЗ + ФЛЮОРЕСЦЕНСІЯ
Пошук проблеми - не знайшов
Виникла ідея перевірити можливі підтікання антифризу за допомогою Liqui Moly Lecksucher - рідина, що світиться в ультрафіолеті та додається до антифризу. Маю лампу ультрафіолетову (плати колись нею травив)
/upload/iblock/1b1/mauj5sa42mnvn3qbrvn2q8nr0tjupuvo/1681712823135.jpg /upload/iblock/4d4/c536oiev8c23qrzxf2m53o3ype1nyim2/IMG_20230419_142206.jpg /upload/iblock/199/8semeer9t3oq9pez10zouironagu0nh8/IMG_20230419_142145.jpg
Доживу до вихідних - перевірю.
199 Відредаговано vlad5229 (2023-04-18 16:09:12)
А машина где ездит?
Я собі на славуту в 2015-му році ставив в якості датчика плату від безконтактного датчика положення дросельної заслонки, зверху кусок пластикової банки. Потім зробив адаптера до якого підключені і бензиновий і газовий датчики для виводу рівня палива на стандартну панель, на чому авто їде, рівень того палива і панель показує. Працює по даний час, враховуючи що показометр стрілочний, завжди знаю коли закінчиться газ.
https://slavuta-club.info/wp-content/uploads/pub/f_226.jpg
https://slavuta-club.info/wp-content/uploads/pub/f_230.jpg
https://slavuta-club.info/wp-content/uploads/pub/f_253.jpg
https://slavuta-club.info/wp-content/uploads/pub/f_254.jpg
Спасибо сказали: jasonua1
200
vlad5229,
Фото не открывается
