1 Відредаговано igorsh88 (Сьогодні 10:03:28)
/upload/iblock/44b/ujhqds2mwin25y0okeil9jdfgwx3oou4/IMG_20230922_185518.jpg /upload/iblock/ede/agjvpsf4eeu8cl40e1vhu6kd8hq3zo7g/IMG_20230922_185546.jpg
/upload/iblock/bfd/dbgs4xa1slxee3ooed3nox3d8tvcd2oe/IMG_20231012_161753.jpg
https://logan.in.ua/upload/iblock/2f9/2dkg3r1btdu7zxmu0epx4c22zdy1aohv/480_640.jpg https://logan.in.ua/upload/iblock/b46/2hlyvyygk7mg0nyk6tlb88hpo1auex6e/VAZ163-_1_.jpg  https://logan.in.ua/upload/iblock/858/51q4d6pd6mqoug6zq22rw4rua4xj3m2m/6400480-_1_.jpg https://logan.in.ua/upload/iblock/195/xo43rd2f45ae2t2vwh3k9fdvkyzv79oi/elektrosxemi_renault_logan_rul_600x800.jpg https://logan.in.ua/upload/iblock/6a1/c033nkp9y65qp6ng7dlypwk8xcydshmk/Bezymyannyy.jpg https://logan.in.ua/upload/iblock/c5c/kjj8o9vlqn1jy4frpa0megbmzqqsvlej/Remont_Largus_1.jpg https://logan.in.ua/upload/iblock/b25/9a2qt142flwvdr7wqixqmva8ns1yl4c4/IMG_20230519_210157-_1_.jpg https://logan.in.ua/upload/iblock/452/kwzpr98u0w17g8966120nvd65iqh0pj3/IMG_20230519_213929.jpg https://logan.in.ua/upload/iblock/881/sshfora44bhsvx3vnaoy0gmghvd8gjzd/IMG_20230914_172105.jpg https://logan.in.ua/upload/iblock/961/qq6q4gfoa10am2oiepcb7znodezl1bhk/IMG_20230925_162024.jpg   https://logan.in.ua/upload/iblock/4e9/gynrgsstp906kkdbylitn0i3gxdsda1m/imgonline_com_ua_Resize_ntSsg3czHQ.jpg https://logan.in.ua/upload/iblock/40e/6fhe9dhwrmyqlbj2ocfalpcduf9ek1fa/elektronne-kerivnitstvo.jpg https://logan.in.ua/upload/iblock/e5e/holph3yxjjs704kcfu5yl5teq6v5o5bb/IMG_20231031_072431.jpg https://logan.in.ua/upload/iblock/c53/bwr6mzwwcochmmo6e84t6d1t75soe9dk/IMG_20231031_072928.jpg https://logan.in.ua/upload/iblock/c39/309rj5xqpqm1ng6525p06nc7tpn2a1wq/imgonline_com_ua_Resize_sYYs767Im6V9i2.jpg   https://logan.in.ua/upload/iblock/930/8r9s7k21hob78t1s7e3stj43i1nencva/imgonline_com_ua_Resize_G48M7NWRo6.jpg   https://logan.in.ua/upload/iblock/529/5yotxcj2zw8aza3cqnrajnttz0y7fszd/imgonline_com_ua_Resize_AIL9k68nl0Dv8k.jpg   https://logan.in.ua/upload/iblock/689/5mtf37g2ttjmj540al3znyu2g4qzjhkm/imgonline_com_ua_Resize_ef9xKA6hPI20.jpg https://logan.in.ua/upload/iblock/1db/6jscetdf9w8vzzpzxlwuo8ijpjcuz3vr/Bez-imeni.jpg https://logan.in.ua/upload/iblock/972/knknql8kgeqaxcj2lr8rundtjidk02jn/16583055-_1_.jpeg
501 Відредаговано igorsh88 (2023-12-31 08:38:36)
gri написав:
3 л концентрату + 3 л дист.води ≈ 5.5 л суміші
Щось я тоже дивуюсь..
Явище контракції - зменшення об'єму водного розчину, в даному випадку етиленгліколя.
Розрахуйки при 0°С: 1 л концетрату + 1 л дистиляту = 1.95 л
/upload/iblock/e2f/593jsku59hfuuure8lcouf33gyk86lj5/IMG_20231230_190835.jpg
Густина:
• етиленгліколя 1.11 г/мл
• дистилята 1.0 г/мл
• суміші 1.08 г/мл
Маса суміші 1.11+1.0=2.11 кг
Об'єм суміші 2.11/1.08≈1.95 л
ГБО BRC обслуговуєте самостійно?
503 Відредаговано gri (2023-12-31 11:02:23)
Не,ну  на 50-100 грамів я згоден,но відсутність півлітри  alc я не міг не замітити при змішуванні антифризу.
504 Відредаговано igorsh88 (2024-01-01 13:19:59)
Yeka написав:
Налаштування, діагностику, зміну конфігурації - самостійно.
Заміна фільтрів, до кінця гарантійного терміну - СТО.
Де можна подивитись/почитать щось по роботі з ПО BRC. Зараз вже стоїть на трьох домашніх машинах.Машини різнопланові,з різними обємами-під одну гребінку не настроїш.Є прога "BRC Calibration Tool",свій шнурок. Базові налаштування,після заміни фільтрів,ремонту редуктора, роблю сам. Глибше не беру,не хватає знань. Те що є в інтернеті і на Ютюбі,на загал,або дуже поверхневе,або мало інформативне.
506 Відредаговано igorsh88 (2024-01-01 14:13:00)
В своїй роботі керуюся інструкцією та відеолекціями технічного директора компанії BRC в Україні. Все, що робив  відображено в: Logan MCV -> Бортовий журнал -> Зміст -> ГБО.
Література:
Інструкція по роботі в програмі Calibration Tool -> Eng, Ru
Відеолекції по GFI (аналог BRC) -> тут
Спасибо сказали: Migen, Yeka2
507 Відредаговано igorsh88 (2024-01-02 12:52:43)
LOGAN. УСТАНОВКА ГБО ОКУПИЛА СВОЮ ВАРТІСТЬ
/upload/iblock/b84/9cmy71u4m9b6bumc31l1hmz6jos51ibh/IMG_1352.jpg
ГБО: BRC.
Вартість: 30 тис. грн.
Термін: 16 міс.
Відстань: 35 тис. км.
Інтервал ТО: 15 тис. км.
Кількість ТО: 3.
Витрати на ТО: 3 тис. грн.
Розхід: 9±1 л/100 км.
Далі - чиста економія в 1±0.25 грн/км.
Спасибо сказали: Migen1
508
Нє,ну як що так,тоді да(не враховувати обслугу ГБО , додаткові геморої з двиглом і тупу динаміку) upp
gri написав:
Якщо прямі руки то обслуговування гбо коштує копійки.
Там фактично міняється 2фільтра, коштують 230грн 2шт
Один фільтр міняється на 10тис км і один на 20тис км
Гемороїв з двигуном ніяких не має, якщо правильне обладнання стоїть і правильно налаштоване. Динаміка така сама як і на бензині
gri написав:
ДТОР,клапн адсорбера?
ДТОР - по OBD показує температуру коректно.
Клапан адсорбера - підсосів повітря немає, MAP 0.3.
Бензонасос - тиск 3.4 Бар
Акумулятор - мінявся
Свічки, форсунки, провода - нові
Прокладки - замінені всі
ГРМ, ролики - нові
Ремінь, ролики - нові
Дросель - електронний, почищений
В планах:
Зняти почистити датчик положення колінчастого валу
Поміряти компресію
Перевірити/відрегулювати клапана
Загалом - не турбує, проявляється не завжди. Цікавить знайти причину.
Які прокладки міняли, уточніть будь ласка, бо хочу подібну профілактику провести поки є натхнення та можливості. Завчасно дякую
Вони(гемори)і так вилазять час від часу,а ГБО-купа додаткових прибамбасів...
Апріорі, не може двигун,заводом зроблений бензиновим, їхати на газу так само...
gri написав:
Перше-Логан явно машина не для перегонів,а подруге після 3-3,5 т обертів,в кого як налаштовано,двигун переходить на бензин-тапкуй скільки влізе.
513 Відредаговано igorsh88 (2024-01-03 20:34:30)
sidalv написав:
В даному -> пості + тут я все детально розписав. Зверніть увагу, що дросель в мене електронний у Вас можливо інший буде. Також я промахнувся з кільцем корпуса фільтра - купував інший.
sidalv написав:
В даному -> пості я все детально розписав. Зверніть увагу, що дросель в мене електронний у Вас можливо інший буде. Також я промахнувся з кільцем корпуса фільтра - купував інший.
супер!). Дякую
515 Відредаговано igorsh88 (2024-01-03 17:50:02)
gri написав:
За час експлуатації жодних проблем. Ставте якісне ГБО, слідкуйте за двигуном і буде Вам щастя.
gri написав:
По заводу - на K4M конструктивно передбачено ГБО.
По динаміці: до 3500 об/хв - змін не відчув, після - так.
ГБО ставлять для економії в першу чергу.
Спасибо сказали: jasonua1
516
Yeka написав:
Згоден.Проте  невеликим доробками к7м можна трохи "оживити".
З таким педантичним відношеням до авто-це безсумнівно. upp
Сумнівна економія...Таксісти в нас ГБОшні машини "посплавляли",їздять на бензині.А вони гроші рахувати вміють...
gri написав:
Навіщо? Для цього є інші двигуни інші машини.
gri написав:
Добре що таксисти нацбанком не керують.
Ми зараз людині захезаєм бортовик і він буде просто"щасливий" від кількості постів не по суті. Пропоную йти,ламать списи,на предмет доцільності використання ГБО в умовах воєнного стану,в іншу тему.
Вибачаюсь,забув про
Yeka написав:
не по суті
gri написав:
Може! Навіть може краще їхати ніж на бензині!
gri написав:
То Вам до проктолога...
520 Відредаговано igorsh88 (2024-01-16 16:12:17)
ПРИСПОСОБА РЕГУЛЮВАННЯ КЛАПАНІВ ПІД ДИНАМОКЛЮЧ - ДОПОВНЕННЯ
• Підготовка - щуп
• Проблемні питання
/upload/iblock/fc4/txanyy3zjy8tym9skn4lu61ir9ns9uw1/IMG_20240105_093845.jpg /upload/iblock/570/g3ps0qi5uc4yuhxl1srx78kdxiappmk9/IMG_20240105_093827.jpg
Мій задум частково потерпів фіаско  sad . Прикупивши, на всяк випадок, нові контргайки та гвинти виявив, що в останніх головка зовсім не квадрат 3 мм, відповідно інструмент для регулювання клапанів не підійшов. В надії вийти із ситуації без "колхозу" заказав рожково-накидний ключ 3 мм, но китайські 3 = 3.2-3.3 мм реальним, що спричиняло люфт при утримані гвинта. Псіханув - звернувся до народного досвіду (vlad5229  upp) допрацював надфілем.
Нові котргайки 7703033205 та гвинти 7700273504
/upload/iblock/4a9/0l8xgr2bxu51pqq7ayuc8ny3b32thh75/IMG_20240105_093045.jpg /upload/iblock/249/km9xejvd3bwihpqyy6cr43ayo83k5ph4/IMG_20240105_093051.jpg
Гвинт, форма головки не квадрат
/upload/iblock/92c/o0zhb29vzv0pf5uxd31aes0e0mskfozm/IMG_20240105_102713.jpg /upload/iblock/957/455r96n8wv4gkkx0fh451v09291ulakw/IMG_20240105_093423.jpg /upload/iblock/e0e/i0gi4gijbaii5q8o2ncroehlww6um04e/IMG_20240105_093338.jpg
Китайський рожково накидний ключ 3 мм по факту 3.2-3.3 мм
/upload/iblock/3e4/xyu4z3y2nrhczmllgnimr258mn4848gt/IMG_20240105_083252.jpg /upload/iblock/3d3/2flivsx370ywj73spki2282n6z0r74ym/IMG_20240105_083301.jpg /upload/iblock/50d/sjjvfd0uvbjjshw626r271oqb2qf1w9m/Screenshot_2024_01_05_08_35_15_934_com.miui.gallery.jpg
Надфіль вирішив проблему
/upload/iblock/da7/b3ikl7jxftf1c6u69fe2odfaxlqxvadz/IMG_20240105_085938.jpg /upload/iblock/39b/n9s7fmf0bgwiqhh2qvha40wcnxnl8nf1/IMG_20240105_093206.jpg /upload/iblock/4e5/fj5ccb21gvu1nfhk0zia9tz9o76p9et3/IMG_20240105_093233.jpg
Прокладка клапаної кришки - Victor Reinz 713162210
/upload/iblock/6e9/j1q9wh2mzl3qxlb49b0iev1hgevsvcox/IMG_20231228_053633.jpg /upload/iblock/3b0/rmtbl3w0eg23csoyktlp0wkhjobh18vs/IMG_20231228_053632.jpg
P.S. Подумав, що клапана потрібно регулювати при ~+20°C. Мені, що весни чекати, гаража то - німа ?  dntknw
gri написав:
Не може, 1 Ступінь стиску замала, потрібно збільшувати кут запалювання, частина енергії тратиться на стискання поршнем суміші яка вже в стані горіння, 2 газоподібний газ витісняє частину повітря на пуску, якщо лямбларегулятор працює, то він ріже паливоподачу.
В мене також був не квадрат.
Так мова йде про температуру двигуна. Чи це самоціль-щоб були лабораторні умови?
523 Відредаговано jasonua (2024-01-05 12:25:51)
gri написав:
На своєму мсв на гбо проїхав без проблем 200тис км.
Один раз сам прокладки редуктора поміняв.
Вартість 200грн І недавно на пробізі 200тис км форсунки баракуда поміняв.
3000грн 4форсунки з налаштуванням вийшли.
Все, проблем за 200тис км на газу не було
524 Відредаговано igorsh88 (2024-01-05 13:07:13)
Yeka написав:
Намагаюсь дотримуватися технічної ноти. Поки все повідкручую та заміню температура двигуна зрівняється з навколишньою ~0°C.
Думаю,то так здається.Теплоємність дввигуна з усіма рідинами і мотлохом не така вже й мала.Можна,в цілях експерименту,заміряти,нічого не розбираючи,час вистивання і від цього відштовхуватись.
