1 Відредаговано igorsh88 (2025-04-14 08:17:07)
/upload/iblock/44b/ujhqds2mwin25y0okeil9jdfgwx3oou4/IMG_20230922_185518.jpg /upload/iblock/ede/agjvpsf4eeu8cl40e1vhu6kd8hq3zo7g/IMG_20230922_185546.jpg
/upload/iblock/bfd/dbgs4xa1slxee3ooed3nox3d8tvcd2oe/IMG_20231012_161753.jpg
https://logan.in.ua/upload/iblock/2f9/2dkg3r1btdu7zxmu0epx4c22zdy1aohv/480_640.jpg https://logan.in.ua/upload/iblock/b46/2hlyvyygk7mg0nyk6tlb88hpo1auex6e/VAZ163-_1_.jpg  https://logan.in.ua/upload/iblock/858/51q4d6pd6mqoug6zq22rw4rua4xj3m2m/6400480-_1_.jpg https://logan.in.ua/upload/iblock/195/xo43rd2f45ae2t2vwh3k9fdvkyzv79oi/elektrosxemi_renault_logan_rul_600x800.jpg https://logan.in.ua/upload/iblock/6a1/c033nkp9y65qp6ng7dlypwk8xcydshmk/Bezymyannyy.jpg https://logan.in.ua/upload/iblock/c5c/kjj8o9vlqn1jy4frpa0megbmzqqsvlej/Remont_Largus_1.jpg https://logan.in.ua/upload/iblock/b25/9a2qt142flwvdr7wqixqmva8ns1yl4c4/IMG_20230519_210157-_1_.jpg https://logan.in.ua/upload/iblock/452/kwzpr98u0w17g8966120nvd65iqh0pj3/IMG_20230519_213929.jpg https://logan.in.ua/upload/iblock/881/sshfora44bhsvx3vnaoy0gmghvd8gjzd/IMG_20230914_172105.jpg https://logan.in.ua/upload/iblock/961/qq6q4gfoa10am2oiepcb7znodezl1bhk/IMG_20230925_162024.jpg   https://logan.in.ua/upload/iblock/4e9/gynrgsstp906kkdbylitn0i3gxdsda1m/imgonline_com_ua_Resize_ntSsg3czHQ.jpg https://logan.in.ua/upload/iblock/40e/6fhe9dhwrmyqlbj2ocfalpcduf9ek1fa/elektronne-kerivnitstvo.jpg https://logan.in.ua/upload/iblock/e5e/holph3yxjjs704kcfu5yl5teq6v5o5bb/IMG_20231031_072431.jpg https://logan.in.ua/upload/iblock/c53/bwr6mzwwcochmmo6e84t6d1t75soe9dk/IMG_20231031_072928.jpg https://logan.in.ua/upload/iblock/c39/309rj5xqpqm1ng6525p06nc7tpn2a1wq/imgonline_com_ua_Resize_sYYs767Im6V9i2.jpg   https://logan.in.ua/upload/iblock/930/8r9s7k21hob78t1s7e3stj43i1nencva/imgonline_com_ua_Resize_G48M7NWRo6.jpg   https://logan.in.ua/upload/iblock/529/5yotxcj2zw8aza3cqnrajnttz0y7fszd/imgonline_com_ua_Resize_AIL9k68nl0Dv8k.jpg   https://logan.in.ua/upload/iblock/689/5mtf37g2ttjmj540al3znyu2g4qzjhkm/imgonline_com_ua_Resize_ef9xKA6hPI20.jpg https://logan.in.ua/upload/iblock/1db/6jscetdf9w8vzzpzxlwuo8ijpjcuz3vr/Bez-imeni.jpg https://logan.in.ua/upload/iblock/972/knknql8kgeqaxcj2lr8rundtjidk02jn/16583055-_1_.jpeg
351 Відредаговано igorsh88 (2023-09-07 16:13:03)
У Вас блок чугун или алюминий?
Блок циліндрів двигуна K4M - чугун.
Головка блока - алюміній.
Піддон - алюміній.
352 Відредаговано igorsh88 (2023-09-08 01:35:59)
сразу не глушу, тогда антифриз и вентилятор охлаждает.
Вирішую дане питання аналогічно додатково вмикаючи пічку на максимум.
353 Відредаговано igorsh88 (2023-09-08 01:07:05)
Наблюдал через программу,  эффективно когда в пробках работает кондиционер то температура держится 90 град.
Даже простое включения кондиционера перед остановкой запускает вентилятор и температура сразу падает.
355 Відредаговано igorsh88 (2023-09-10 21:22:15)
ІНВЕРТОР, МОНТАЖ
/upload/iblock/356/1fht161if02ooqmvvitl9dxcl6fgs6uk/IMG_20230910_172841.jpg /upload/iblock/2b5/s7vtxuq2fsobd14ni9e75plz9vc6nxvm/IMG_20230910_172831.jpg
Встановив раніше придбаний інвертор 12->220 під бардачок
Провід ПВ-3 переріз 16 мм2, клеми, термоусадка
/upload/iblock/a7f/2jhc5e8uopv3hth984n78s3945sw99yf/IMG_20230910_135700.jpg /upload/iblock/57f/zpjtullh9rdrizyds5pe86qt6fxfwx2s/IMG_20230910_140132.jpg /upload/iblock/4ef/79if0hspsq8057gdjtb1nqxubxj8lfjv/IMG_20230910_140925.jpg
Шампур в поміч
/upload/iblock/3e6/fvdxhtt6twzy3zs1gnputxwvhcbde3dt/IMG_20230910_141108.jpg /upload/iblock/9d2/oh8hwg5ch0volhzrxj13bqdxfjragf89/IMG_20230910_141729.jpg /upload/iblock/f42/5ixg2ts1zyl3ab5jk5dpz1asmeyzjei5/IMG_20230910_142919.jpg
До акума приєднав
/upload/iblock/4bf/na2nbqvk5d4k4mmo9pw75wz3tnas7o6d/IMG_20230910_165823.jpg
Зняв псевдо заземлення та захист
/upload/iblock/392/67ho0ymt88281b0jw5jy0pt1h7tis8hv/IMG_20230910_151834.jpg
Фіналочка
/upload/iblock/5c5/9mjrul6yuhxqzg4qanjwnhi3p0qjxc15/IMG_20230910_171959.jpg
Переваги:
1. Очевидні  smoke
Недоліки:
1. Шум вбудованого вентилятора охолодження.
2. Ускладнена заміна салонного фільтра.
3. Забув вимкнути - прощавай акум  lol
4. 500 Вт сварку не потяне  focus
5. Провода одного кольору - червоного
Недоліки:
1 в движении вообще не слышу, на стоянке - можно громкость у магнитолы добавить)
2 не мешает совсем, может у к4м другое расположение фильтра?
3 выключатель массы на АКБ (вечером в конце поездки ВЫКЛ), второй вариант - реле напряжения, при напруге менее 13В, т.е. не работаюем двигателе, питание на инвертор не подается. Себе ставил на подогрев сидений.
4 вари ацетиленом, полная автономность ))), при сложенных сиденьях в МСВ помещаются кислородный и ацетиленовый баллоны со всеми шлангами и горелкой, на переднем пассажирском можно уместить сварщика))).
5 даже не знаю что предложить, можно провести голосование и большинством голосов признать второй красный провод черным, или как сейчас принято --афропровод ))).
357 Відредаговано igorsh88 (2023-09-18 12:20:05)
ТЕСТЕР-ЗАРЯДКА АКБ
/upload/iblock/413/sfi071kz328hnfxw6zi0ze8mtkggo0tm/IMG_20230912_083320.jpg /upload/iblock/71a/1f4gr7z9haad82pgtte6z94r3rpwbqm1/IMG_20230912_084035.jpg
Напруга АКБ після нічної стоянки падає до 12.0-12.3 В, хоча стартер крутить нормально та витік струму відсутній. Пацієнту 5+ років* з метою діагностики стану придбав тестер-зарядку Konnwei KW510.
Тест АКБ: стан батареї 73%, рівень заряду 61%, внутрішній опір 6.3 мОм (норма 4-6 мОм), пусковий струм 440 А (номінал 600 А)
/upload/iblock/bf2/66evhkvt1zdrka58rzgx2cmed3wol5c0/IMG_20230912_131149.jpg /upload/iblock/fa2/kqtl1r5voxqqgljr58vo7q6hxp1qu7cg/IMG_20230912_131259.jpg
Тест системи пуска: просадка до 9.3 В (норма 10+ В)
/upload/iblock/4e7/qvc3lb0425t71kk9whjauf25ase292tv/IMG_20230912_131601.jpg /upload/iblock/599/wlzecze1k8gn4xwaavov8io7yljv59fe/IMG_20230912_132042.jpg
Тест системи зарядки: напруга 14.6 В, пульсації 120 мВ, в нормі
/upload/iblock/779/w64ux31tea5b1ev8ks6mgn10jut26epg/IMG_20230912_132202.jpg /upload/iblock/b6a/kl6jgww0mepphe7kiiu8kf8v47lmbl8q/IMG_20230912_132254.jpg
Висновок: втрата ~30% ємності. Спробую провести чудо-десульфатацію, цікаво що зміниться.
* - Згідно маркування Bosch: C7C854262 дата 06.2018 р
/upload/iblock/e2e/5ysjryj30e1v6yb15rg230iibjkex34x/4183c5as_960.jpg /upload/iblock/5b0/9qcx9aio652ogmgfp9y16zvu6zd8h798/IMG_20230913_134155.jpg
Розібрав, Китай, зроблено якісно
/upload/iblock/9d7/0ogqplut21b0k4jdwghlx9zeyjapmx36/IMG_20230912_111926.jpg /upload/iblock/68a/gyg98guem0ht5r3ub5vy9q1q3tdivlmx/IMG_20230912_110452.jpg /upload/iblock/cd0/ftbu2rmjtj34kuq9txxg8aoidd0d6vuf/IMG_20230912_110457.jpg /upload/iblock/c53/xhim7br9nh4t21voh38l1zxcd1cm659o/IMG_20230912_110659.jpg /upload/iblock/7e9/bjh3c04o9za7hda36244b885hmnih23k/IMG_20230912_110622.jpg /upload/iblock/782/093n6cxrvuupd7s1itnqxbbgbrfne249/IMG_20230912_110433.jpg
igorsh88,
61% заряда очень мало,  и это сейчас тепло..
Может можно зарядить пульсацией на ночь?
Самое неприятное если сдохнуть может внезапно зимой не завестись.
Спостерігаємо.
Так і буде. Я спочатку також багато експериментував с зарядками, потім як АКБ починало глючити то просто його міняв.
ТЕСТЕР-ЗАРЯДКА АКБ
Напруга АКБ після нічної стоянки падає до 12.0-12.3 В, хоча стартер крутить нормально та витік струму відсутній. Пацієнту 5 років* з метою діагностики стану придбав тестер-зарядку Konnwei KW510.
Что -то я не увидел - а заявленная производителем какая ёкость?
362 Відредаговано igorsh88 (2023-09-15 18:19:48)
Прилад ємність не міряє. Сам акумулятор ємністю 61 Аh
igorsh88,
По заряду уже 40  wink
Зі свого досвіду з кислотними АКБ - критично хреновий показник... Зимою навіть бензиновий двигун може не запустити.
Спасибо сказали: floyd471
365
Sivil написав:
Это если аккумулятор полностью заряжен. А если заряд 61% - терпимо.
366 Відредаговано igorsh88 (2023-09-18 12:19:29)
ДЕСУЛЬФАТАЦІЯ АКБ
Провів приладом ~30 годинну десульфатацію АКБ
Поточна АКБ:
Bosch S5 Silver Plus 61Ah 600A R+ (S5 004), 242×175×175.
Результати:
SOH: 73% -> 88% - загальний стан
SOC: 61% -> 71% - рівень заряду
R: 6.2 мОм -> 5.2 мОм - внутрішній опір
I: 441 A -> 531 А - пусковий струм
U: 12.29 В -> 12.37 В - напруга АКБ
Umin: 9.3 В -> 9.8 В - просадка напруги при старті
Висновки: Позитивна +10% динаміка присутня но загалом - нічого не змінилося. Після нічної стоянки напруга просідає до 12.3 В  (з увімкненням світла фар до 11.9 В). Пятирічний акум доживає останній рік.
На заміну розглядаю:
63 Ah (242×175×190):
– Bosch S5 Silver Plus 63Ah 610A R+ (S5 005)
– Varta 6CT-63 Silver Dynamic (D15)
77 Ah (278×175×190)
– Bosch S5 Silver Plus 77Ah 780A R+ (S5 008)
– Varta 6СТ-77 Silver Dynamic (E44)
Література: Офіційний дилер Varta
привет! на ютубе есть видео, называется- 100 процентный способ восстановления старого акб!
смешное)))
Logan 1.5dci , Ravon R2
368 Відредаговано kerjanuch (2023-09-18 15:59:05)
ДЕСУЛЬФАТАЦІЯ АКБ
Поточна АКБ:
Результати:
77 Ah (278×175×190)
Не так уж всё и критично. Может ещё и до следующей зимы дотянет. У меня с завода 45 Ач стоял - 9,5 лет прожил. А этот наверное в работе года 4,5 только.
из собственного опыта скажу что Topla хороший аккум - 3 раза по 6 лет на жиге стоял, а на автомобиле с нормальным зарядным дольше проживёт. Даже тесть удивился - у него не один аккум дольше 4 лет не жил - он вообще ими не занимался - вечно засранный, а тут 6 лет протянул.
Спасибо сказали: igorsh881
369 Відредаговано igorsh88 (2023-09-19 14:38:44)
ЗОВНІШНІЙ МІКРОФОН
/upload/iblock/439/6ti7a9ajtfdxcnh1pd0u8fk492moe99r/IMG_20230919_134825.jpg /upload/iblock/b36/xgmw2rezszva13mq4fznllxoxjhndngq/IMG_20230919_105835.jpg
В штатний мікрофон андроїд магнітоли мене не чули. Замінив на зовнішній розмістивши на лівій стійці та екранувавши провід. Трандіти стало зручніше.
/upload/iblock/9d0/jp3q4gfo5gct3e19s3ebm2crnw51z4yp/IMG_20230919_105520.jpg /upload/iblock/ba0/x0itxdse9czq70u9dfkwy395n3cecaxx/IMG_20230919_105341.jpg /upload/iblock/749/lk079bkcbo18g6f0hz7nnlum8go0x7ly/IMG_20230918_150816.jpg
ДЕСУЛЬФАТАЦІЯ АКБ
Малувато, я свій перший  раз два тижні цілодобово тримав. Після відключення зарядки і 12-ти годинного відстоювання на клемах яка напруга.
371 Відредаговано igorsh88 (2023-09-20 13:48:44)
Ого! shok немаю стільки часу знущатись dntknw авто щоденно нуна
/upload/iblock/f2c/rua32oh52do3dwwxbi6ti3v15emj3eyh/IMG_20230920_134637.jpg 12.3В
VH написав:
привет!...100 процентный способ восстановления акб!
Хай Бобра! Перед початком зими застосую його upp
372 Відредаговано floyd47 (2023-09-21 10:19:48)
авто щоденно нуна
А придбати ше одну АКБ? Ні? У якості аварійної і до автівки, і у гараж 12 Вольт напруги. Ви ж стільки коштів вгепуєте в оті усі ваші кєтайські прибамбаси, невже на ше один акум не вистачає? У мене на іншому сигналізація гаражу сидить.
п.с. на тому відео сама цінна інфа на 3:21.
373 Відредаговано igorsh88 (2023-09-24 10:26:28)
Звісно доведеться нову батарейку брати. Китайська зарядка має функцію діагностики, що нуна при перевірці нового АКБ.
З аварійними "резервами" проблеми відсутні  smoke
Два АКБ Koyosonic 120 Ah GEL
Два ДБЖ Volt polska Sinus Pro 1000 Вт 12/230 В;
Бензогенератор HAGEN TTD-MG-4000SK
100 л пального;
20 кубів дров.
igorsh88, і шо, навіть американських сірників, здатних горіти під водою, нема?
Ну там не було цілодобово, як треба було їхати, то ставив на машину і їхав, потім знову ставив на десульфацію.
Як показує досвід, якщо десульфатувати цілодобово, то потрібно під час зарядки міряти напругу на клемах, я міряю цифровим тестером в режимі два знаки після коми, якщо напруга перестала підніматись, то фінал. А якщо вмикати тільки на день і давати відстоюватись на ніч, то міряти напругу після відстою, якщо перестала відніматись то фінал.
Треба міряти тестером без нагрузки.
