1 Відредаговано igorsh88 (2026-04-03 20:10:16)
225 т.км ТО, Elf 5w-40
https://logan.in.ua/upload/iblock/2f9/2dkg3r1btdu7zxmu0epx4c22zdy1aohv/480_640.jpg https://logan.in.ua/upload/iblock/b46/2hlyvyygk7mg0nyk6tlb88hpo1auex6e/VAZ163-_1_.jpg  https://logan.in.ua/upload/iblock/858/51q4d6pd6mqoug6zq22rw4rua4xj3m2m/6400480-_1_.jpg https://logan.in.ua/upload/iblock/195/xo43rd2f45ae2t2vwh3k9fdvkyzv79oi/elektrosxemi_renault_logan_rul_600x800.jpg https://logan.in.ua/upload/iblock/6a1/c033nkp9y65qp6ng7dlypwk8xcydshmk/Bezymyannyy.jpg https://logan.in.ua/upload/iblock/c5c/kjj8o9vlqn1jy4frpa0megbmzqqsvlej/Remont_Largus_1.jpg https://logan.in.ua/upload/iblock/b25/9a2qt142flwvdr7wqixqmva8ns1yl4c4/IMG_20230519_210157-_1_.jpg https://logan.in.ua/upload/iblock/452/kwzpr98u0w17g8966120nvd65iqh0pj3/IMG_20230519_213929.jpg https://logan.in.ua/upload/iblock/881/sshfora44bhsvx3vnaoy0gmghvd8gjzd/IMG_20230914_172105.jpg https://logan.in.ua/upload/iblock/961/qq6q4gfoa10am2oiepcb7znodezl1bhk/IMG_20230925_162024.jpg   https://logan.in.ua/upload/iblock/4e9/gynrgsstp906kkdbylitn0i3gxdsda1m/imgonline_com_ua_Resize_ntSsg3czHQ.jpg https://logan.in.ua/upload/iblock/40e/6fhe9dhwrmyqlbj2ocfalpcduf9ek1fa/elektronne-kerivnitstvo.jpg https://logan.in.ua/upload/iblock/e5e/holph3yxjjs704kcfu5yl5teq6v5o5bb/IMG_20231031_072431.jpg https://logan.in.ua/upload/iblock/c53/bwr6mzwwcochmmo6e84t6d1t75soe9dk/IMG_20231031_072928.jpg https://logan.in.ua/upload/iblock/c39/309rj5xqpqm1ng6525p06nc7tpn2a1wq/imgonline_com_ua_Resize_sYYs767Im6V9i2.jpg   https://logan.in.ua/upload/iblock/930/8r9s7k21hob78t1s7e3stj43i1nencva/imgonline_com_ua_Resize_G48M7NWRo6.jpg   https://logan.in.ua/upload/iblock/529/5yotxcj2zw8aza3cqnrajnttz0y7fszd/imgonline_com_ua_Resize_AIL9k68nl0Dv8k.jpg   https://logan.in.ua/upload/iblock/689/5mtf37g2ttjmj540al3znyu2g4qzjhkm/imgonline_com_ua_Resize_ef9xKA6hPI20.jpg https://logan.in.ua/upload/iblock/1db/6jscetdf9w8vzzpzxlwuo8ijpjcuz3vr/Bez-imeni.jpg https://logan.in.ua/upload/iblock/972/knknql8kgeqaxcj2lr8rundtjidk02jn/16583055-_1_.jpeg https://logan.in.ua/upload/iblock/50e/21vm4v86bmt06gvu8dg0f2pmvbtpvy7y/imgonline_com_ua_Resize_kIxMxOj9jQZwpo.jpg
526 Відредаговано igorsh88 (2024-01-05 18:24:11)
SANDERO. ОЧИЩУВАЧ ПАЛИВНОЇ СИСТЕМИ
/upload/iblock/575/n6gcsh70ooah5cj07wzckj1iuivjjrii/IMG_20240105_150902.jpg
Ускладнений ранковий старт двигуна в мінус повторився, при цьому в +0..1 °C запуск завжди без проблемний. В пошуках причини вирішив очистити бак від можливої вологи.
Очищувач паливної системи Pro-Tec Fuel Line Cleaner P1101
Засіб для очищення паливної системи видаляє робочий бруд та відкладення паливної системи від бака до камер згоряння. Безпечно видаляє вологу з усієї паливної системи. Видаляє смолисто-коксові залишки та відкладення сажі в головці блоку циліндрів, змащує та утворює захисний шар від корозії та іржі.
Купував на Autoprofishop.in.ua
Спирт
Спасибо сказали: igorsh881
528
Не може
Ну, Вам, з Тернополю, відніше як може їхати моє авто...
Бо я писав не теорію з дивану, а особистий досвід...
Спасибо сказали: jasonua1
529 Відредаговано igorsh88 (2024-01-09 16:03:19)
SANDERO. НЕДОГРІВ
/upload/iblock/cf4/p0oy3p2wgg7oqmdqpbboopavd3k4oz39/Screenshot_2024_01_06_12_04_01_688_org.prowl.torque.jpg /upload/iblock/acb/3xsyg6aue2bw1cchqh2570u31xifqlsd/Screenshot_2024_01_06_12_04_01_688_org.prowl.torque.jpg
Звернув увагу, що температура двигуна більше 80 °C не піднімається. Згідно документації - робоча 89 °C. У звязку з чим замовив:
Термостат 8200772985 - оригінал
/upload/iblock/4fd/ogr7sa7sw4hfybuelybya6jfc5gc4ngp/Termostat_Renault_8200772985_oxlazhdayushhaya_zhidkost_side1_800x800_1623708889.jpg
Корпус термостата ASAM 32939 - алюміній
/upload/iblock/926/2t6d63j6tjt7h3s0560klpd08201vzgw/7781957_41378023.jpg
Потовщену прокладку термостата - Masuma P102
/upload/iblock/b8b/6bu2qhk89nfqwit7imk2mz4w2zscd190/p102.jpg
530 Відредаговано kerjanuch (2024-01-07 13:21:27)
LOGAN. УСТАНОВКА ГБО ОКУПИЛА СВОЮ ВАРТІСТЬ
/upload/iblock/b84/9cmy71u4m9b6bumc31l1hmz6jos51ibh/IMG_1352.jpg
ГБО: BRC.
Вартість: 30 тис. грн.
Термін: 16 міс.
Відстань: 35 тис. км.
Інтервал ТО: 15 тис. км.
Кількість ТО: 3.
Витрати на ТО: 3 тис. грн.
Розхід: 9±1 л/100 км.
Далі - чиста економія в 1±0.25 грн/км.
Как вы насчитали такой большой пробег окупаемости? У меня 25 тыс получается
531 Відредаговано igorsh88 (2024-01-07 17:22:21)
https://logan.in.ua/upload/iblock/4d7/0k11gurf59mhtnq0lp1c0y3o7irjxrmt/lpg336.jpg
https://logan.in.ua/upload/iblock/576/7tmgwieg5rrb0l2xg3ktjqe471b7r7k0/lpg3.jpg
Спасибо сказали: Sivil1
532 Відредаговано gri (2024-01-07 15:44:57)
Ну,ти ,блін,бухгалтер...
На робочому елементі(жовтому) е цифри?
Треба порівняти діаметр отворів каналу паровідвода "рідного"і купленого корпусів (шланг на бачок).Якщо в алюмінію більший-буде піна в системі охолоджування,пьєц не грітиме.До речі,обіцяють мороз добрий,що з  з заводом авто буде?
533 Відредаговано igorsh88 (2024-01-09 19:12:11)
gri написав:
На диво, після чистки бака від води заводиться з півоберта.
534 Відредаговано igorsh88 (2024-01-10 13:24:50)
SANDERO. ТЕРМОСТАТ. КОРПУС. ПРОКЛАДКА
Передісторія - недогрів
/upload/iblock/54c/9h08a8xdcs0m8f60v5j75q31lidmwf8f/IMG_20240109_140909.jpg /upload/iblock/4d0/d35we74fj6vntipuh6hsaxe6njmdxx1r/IMG_20240109_141004.jpg
Корпус Asam 32939 - алюміній, діаметр паровідводу 8/12 мм
/upload/iblock/0c0/u1p5rxwhdnvyf1e265rugw9nqmkpxukq/IMG_20240109_141112.jpg /upload/iblock/ae9/sb3scta45zjxapt2d4ykaktmibzcwe85/IMG_20240109_145503.jpg /upload/iblock/c9e/8lv0mj9gurwphmayi5r35y0c6foe85ra/IMG_20240109_145526.jpg
Термостат 89°C, експериментуй показав ... - працездатність vissla
https://logan.in.ua/upload/iblock/c83/7e8oqjidtswq0fydy8sllltsyqdplo2y/IMG_20240109_160835.jpg
Потовщена прокладка термостата Masuma P102
/upload/iblock/abf/0qhwqx3w0pdfzvtzdxz3djomdnns72to/IMG_20240109_141154.jpg
Порівняння товщин: оригінал 3-4 мм, Masuma 5-6 мм
/upload/iblock/cdd/mtanr8xjcnyj2bbe397ceai9lb9bxc7l/IMG_20240109_141334.jpg /upload/iblock/a52/cb2a5bh36ilylldwexci290rawub9g08/IMG_20240109_141445.jpg /upload/iblock/5f1/vw482qq1kq1pr12htujphb82ggd2hags/IMG_20240109_141529.jpg
Порівняння в корпусі термостата: ~ +2 мм
/upload/iblock/589/330mghnrqz08rp1zkkljd438ux68lub2/IMG_20240109_141727.jpg /upload/iblock/8dd/dwcsu17f22u1q9q7z3nf5mfdzsv96hw3/IMG_20240109_141825.jpg
Ну і прекрасно.А з термосом старим що?Як я зрозумів,він працює адекватно,але недогрів є?
536 Відредаговано igorsh88 (2024-01-10 19:06:23)
Було на Логані, два роки їздив не знав доки ELM-ку не вткнув. Поміняв термостат - двигун вийшов на робочу і пічка загріла.
igorsh88, а товстіша прокладка термостата що дає?
538 Відредаговано igorsh88 (2024-01-11 12:36:41)
Запобігає течі антифризу при коливанні площини прилягання корпуса термостата.
539 Відредаговано igorsh88 (2024-01-15 09:27:53)
SANDERO. ЗАМІНА ТЕРМОСТАТА ТА КОРПУСА
Детальки - термостат, корпус, прокладка
/upload/iblock/3ff/ajmgroc9hxh91eoe8b460i7yw7h1vpq3/IMG_20240114_133149.jpg /upload/iblock/99c/h7rxvpa0zzo8g55ryjgje4t6z9nnhcz0/IMG_20240114_133835.jpg
Злив 2.5 л антифризу
/upload/iblock/4e6/n9aprbxwyfi3u4k1p6s5ast23e241cbl/IMG_20240114_124013.jpg /upload/iblock/3b5/52sqjvzgfwb778l0uitbtvtgwuija1g1/IMG_20240114_123520.jpg /upload/iblock/7a7/a1yslgyrzxdp7hic0wpxif93bql8dp54/IMG_20240114_122512.jpg
Старий термостат - пошкоджений гумовий ущільнювач
/upload/iblock/5fd/va1qu8oc25jh8n46gutpezodambj36kv/IMG_20240114_130251.jpg /upload/iblock/a75/h3tvaph781x5ixpwnbjbtw6n24h1w2pp/IMG_20240114_130246.jpg /upload/iblock/780/tegcqa9lqznv9t6asfu0t0pb3zjm8usm/IMG_20240114_130306.jpg
Новий термостат, хомути, корпус момент затяжки 10 Нм
/upload/iblock/63b/s0lb3nqz92gctq94posi80sh3vahm673/IMG_20240114_131210.jpg /upload/iblock/f5d/nwvwds0vftpy9xyj3slnd2r0kso87bcd/IMG_20240114_125057.jpg /upload/iblock/9b6/ap8ykior1bb1e7fheeuuwo13q8qsk91m/IMG_20240114_132533.jpg
P.S. Потовщену прокладку Masuma P102 не встановив - завелика для металевого корпуса, лишив оригінальну.
Щілина в площині прилягання з Masuma P102
/upload/iblock/f83/2a10op8j1snckw19mqatpj5una3aqot4/IMG_20240114_131358.jpg /upload/iblock/989/w172m9sp3zxfyr4rn0gkvo9fjxssmukr/IMG_20240114_131622.jpg
Помогло?
541 Відредаговано igorsh88 (2024-01-15 22:57:43)
Так, двигун швидше виходить на робочу 89°C і тримає її в русі.
542 Відредаговано igorsh88 (2024-01-16 18:48:07)
ПРИМІТКА. РЕГУЛЮВАННЯ КЛАПАНІВ + 0°C = ?
• Підготовка - щуп
• Проблемні питання
• Приспособа під динамоключ - реалізація. Гайки, гвинти, прокладка
Регулювати клапани рекомендують при температурі двигуна ~20°C. Зима на дворі і до весни далеко.
Варіант запропонований Yeka:
Yeka написав:
Можна, в цілях експерименту, заміряти, нічого не розбираючи, час вистивання і від цього відштовхуватись.
Потерпів фіаско - двигун швидко охолоджується. Враховуючи, що планую замінити гайки, гвинти, відмити кришку, старий герметик - не встигну. В пошуках відповіді на проблемне питання провів розрахуйки, згідно яких похибка не суттєва та менше номіналу щупа.
Розрахуйки. Похибка ~0.02 мм
Лінійне подовження стальної деталі:
dL=L*dT*a
де:
dL - подовження при зміні температури на dT, мм;
dT - зміна температури, град;
a - коефіцієнт лінійного розширення сталі ~13E(-6) (1/град).
Сталева деталь (клапан) довжиною 100 мм при зміні температури на 20 градусів скорочується/подовжується на:
dL=100*20*13E(-6)=0.026 мм
возможно таблица зависимости зазора от Т-ры поможет, правда для вазовской классики https://www.drive2.ru/b/2443099/
544 Відредаговано igorsh88 (2024-01-22 12:59:40)
ЩУП ОДИН, РІВНЯ - ДВА
https://logan.in.ua/upload/iblock/ab9/609svuseoq7b1x7kjiklar1gykowu55b/IMG_20240117_135831.jpg
https://logan.in.ua/upload/iblock/106/dyn076sq34greqenkintm7lpigaiv9tf/IMG_20240117_135902.jpg
З однієї сторони повний з іншої 2/3 рівня. Кому вірити  dntknw ?
Примітка: щуп входить під кутом в картер. Можливо, в цьому причина
/upload/iblock/4eb/sls45qmgpoknq49tt8fa0w2leuava0fo/k4m2.jpg
545 Відредаговано igorsh88 (2024-01-22 13:52:06)
SANDERO. РЕГУЛЮВАННЯ КЛАПАНІВ K7M
Підготовка:
• Щуп
• Проблемні питання: Зазори, моменти, прокладки?
• Проблемне питання: Як регулювати зимою?
До зняття кришки:
• Дата/пробіг останього регулювання - невідомий;
• Стан внутрішніх елементів - лаковий наліт;
• Наявність стуку клапанів - не виявлений;
• Герметик - присутній;
/upload/iblock/da4/wutm9zh0y4c4slexq88vcos2y1zhpxio/IMG_20240121_083554.jpg /upload/iblock/c8c/de7paoqcxl3zr6s6ur3ps4r8wzztmmh0/IMG_20240116_215544.jpg
Після зняття кришки пандори:
/upload/iblock/517/v3dmd5zwlrn1yp36balo8125d73dl4p9/IMG_20240121_084509.jpg /upload/iblock/226/aelp2zbncoz6sr8cjnud54al1oq7l2yq/IMG_20240121_084524.jpg
Поточні зазори клапанів 1-2-3-4 циліндра:
• Впуск: 0.1 мм - 0.1 мм - 0.1 мм - 0.15 мм
• Випуск: 0.15 мм - 0.25 мм - 0.3 мм - 0.25 мм
Після чистки:
/upload/iblock/1cb/uecbrih4a25qxhnj536y1t9mg31m81bx/IMG_20240121_174514.jpg /upload/iblock/997/lpyryo2pn5sv6asz0cjur135wxoegyp5/IMG_20240121_165025.jpg
Замінено:
• Контргайки штовхачів - 8 шт
• Штовхачи - 8 шт
• Металеву прокладку
/upload/iblock/22b/1856gouteaz9maaooubtx26aazdzcd2i/IMG_20240121_174439.jpg /upload/iblock/a93/cdq88thxjtsbtgo9ibj33d8sua9pmawh/IMG_20240121_141259.jpg
Нові зазори клапанів 1-2-3-4 циліндра:
• Впуск: 0.15 мм - 0.15 мм - 0.15 мм - 0.15 мм
• Випуск: 0.25 мм - 0.25 мм - 0.25 мм - 0.25 мм
/upload/iblock/af8/fss51dmgk2ouozkc31d70lc6i3k0yg60/IMG_20240121_164638.jpg /upload/iblock/bef/3oss3mhky6fuxio2efgf539sum671q10/IMG_20240121_174126.jpg
Чим чистив:
/upload/iblock/632/dnmmyxuk8334n3c35evlr2j3lm5n6r5v/IMG_20240117_163912.jpg /upload/iblock/cee/0oy4i84v297olbz9w59zz0ij128akcsi/IMG_20240121_093720.jpg /upload/iblock/245/003uu7nlzy062ozh6acuvtpyzm20wje6/IMG_20240121_161113.jpg
Результат:
• Змін не відчув
А що попередники лили? Не Кастрол часом?
Yeka, У мене був подібний наліт, коли лилось 10-w40.
Лево написав:
Тут важлива не густина, а виробник масла.
Брав Хонду з пробігом.Там,під клапанкою, була подібна ситуація,але в значно в меньшій кількості. Минулий власник їздив на Кастролі,знаю напевно.Перевів машину на Elf і він все повідмивав. не одразу,десь тисяч за 40 пробігу-4 заміни масла.
Змін не відчув
Їх і не мало бути.От очисник двигуна-сильна штука.В меньших ємностях існуе?
