1 Відредаговано igorsh88 (Вчора 09:05:27)
https://logan.in.ua/upload/iblock/2f9/2dkg3r1btdu7zxmu0epx4c22zdy1aohv/480_640.jpg https://logan.in.ua/upload/iblock/b46/2hlyvyygk7mg0nyk6tlb88hpo1auex6e/VAZ163-_1_.jpg  https://logan.in.ua/upload/iblock/858/51q4d6pd6mqoug6zq22rw4rua4xj3m2m/6400480-_1_.jpg https://logan.in.ua/upload/iblock/195/xo43rd2f45ae2t2vwh3k9fdvkyzv79oi/elektrosxemi_renault_logan_rul_600x800.jpg https://logan.in.ua/upload/iblock/6a1/c033nkp9y65qp6ng7dlypwk8xcydshmk/Bezymyannyy.jpg https://logan.in.ua/upload/iblock/c5c/kjj8o9vlqn1jy4frpa0megbmzqqsvlej/Remont_Largus_1.jpg https://logan.in.ua/upload/iblock/b25/9a2qt142flwvdr7wqixqmva8ns1yl4c4/IMG_20230519_210157-_1_.jpg https://logan.in.ua/upload/iblock/452/kwzpr98u0w17g8966120nvd65iqh0pj3/IMG_20230519_213929.jpg https://logan.in.ua/upload/iblock/881/sshfora44bhsvx3vnaoy0gmghvd8gjzd/IMG_20230914_172105.jpg https://logan.in.ua/upload/iblock/961/qq6q4gfoa10am2oiepcb7znodezl1bhk/IMG_20230925_162024.jpg   https://logan.in.ua/upload/iblock/4e9/gynrgsstp906kkdbylitn0i3gxdsda1m/imgonline_com_ua_Resize_ntSsg3czHQ.jpg https://logan.in.ua/upload/iblock/40e/6fhe9dhwrmyqlbj2ocfalpcduf9ek1fa/elektronne-kerivnitstvo.jpg https://logan.in.ua/upload/iblock/e5e/holph3yxjjs704kcfu5yl5teq6v5o5bb/IMG_20231031_072431.jpg https://logan.in.ua/upload/iblock/c53/bwr6mzwwcochmmo6e84t6d1t75soe9dk/IMG_20231031_072928.jpg https://logan.in.ua/upload/iblock/c39/309rj5xqpqm1ng6525p06nc7tpn2a1wq/imgonline_com_ua_Resize_sYYs767Im6V9i2.jpg   https://logan.in.ua/upload/iblock/930/8r9s7k21hob78t1s7e3stj43i1nencva/imgonline_com_ua_Resize_G48M7NWRo6.jpg   https://logan.in.ua/upload/iblock/529/5yotxcj2zw8aza3cqnrajnttz0y7fszd/imgonline_com_ua_Resize_AIL9k68nl0Dv8k.jpg   https://logan.in.ua/upload/iblock/689/5mtf37g2ttjmj540al3znyu2g4qzjhkm/imgonline_com_ua_Resize_ef9xKA6hPI20.jpg https://logan.in.ua/upload/iblock/1db/6jscetdf9w8vzzpzxlwuo8ijpjcuz3vr/Bez-imeni.jpg https://logan.in.ua/upload/iblock/972/knknql8kgeqaxcj2lr8rundtjidk02jn/16583055-_1_.jpeg https://logan.in.ua/upload/iblock/50e/21vm4v86bmt06gvu8dg0f2pmvbtpvy7y/imgonline_com_ua_Resize_kIxMxOj9jQZwpo.jpg
igorsh88, ближний свет хороший (особенно левая фара- почти идеал), дешевые китайцы и рядом не стояли, похоже есть пару светлых пятен выше, но могу ошибаться. За дальний врать не буду. У минилинзы нет такой *галки* и ширина меньше (хуже освещает правую обочину). Световой поток по точкам, пусть спецы меряют, хотя при желании есть проги под телефон, но то такое))).
727 Відредаговано Сіренький (2025-09-06 00:00:36)
alexei74, дивлюсь в інстаграмі канал тих, хто продає і займаєтья переробкою фар.
1 місце звісно лінзи але бюджет.
2 міні лінза в цоколі Н4 нам катить  орієнтовно 2600грн
3 якісний діод під рефлекторну фару 1000-1500
оптимально їхати до них вставляти те і те таі дивитися, що залишит
хто зна, як із реальним ресурсом роботи, не перегорає швидко?
729 Відредаговано igorsh88 (2025-09-09 17:11:58)
ПРАВА ОПОРА
https://logan.in.ua/upload/iblock/c81/8a07ar18qh5ba9rmyk8drxqs55158j1i/IMG_20250906_085545.jpg
Щось не подобається вона мені, просівша і в тріщинах.
Нова, для прикладу, має такий вигляд
https://logan.in.ua/upload/iblock/7f8/pzsqr1kkdruiv709nx9yp9k91rjrxzl6/IMG_20250909_163015.jpg
Сіренькиiй, в целом согласен с вами, но по п.3 есть возражения, качественный диод стоит, как показывает опыт igorsh88, совсем другие деньги и нет гарантии что в фаре другого авто СТГ будет такой же четкой. Тут все строго индивидуально,
Сіренький написав:
За рефлекторную фару ничего не скажу, не пробовал. Но что больше всего меня поражает, вникать в суть почти никто не хочет, идут в магазин (на автобазар) и по совету продавцов берут самый дешманский китай, а потом сами же всей страной ночью и страдаем от кривого света. Хотя у знакомого продавца стоит крутая оптика в фарах, но в продаже у него ее нет - не берут, дорого))).
alexaY, ну так смотря что поставил, первые поколения китайцев с вентилятором горели быстро - пыль и грязь под капотом, клин вентилятора и чип сгорает. Если как у Игоря - живет дольше, но там и мощность меньше, но это ж Филипс заводской, а не подвальный китай - жить будет долго.
ПРАВА ОПОРА
если еще и вибрации на ХХ, то сразу менять. Только не на LEMFOERDER 34798 01, гадость редкая, причем сразу после замены.
731 Відредаговано igorsh88 (2025-09-09 16:53:48)
alexei74 написав:
Чому?
Стара опора, скоріш за все, від Lemforder (маркування співпадає)
/upload/iblock/de6/r7f4rz1c4mfgevtg3bh2xe4k3ojd2nj8/IMG_20250906_090431.jpg /upload/iblock/8f5/umghrh7xdq6t67hejjk4p53g8altfv4c/IMG_20250906_090948.jpg
Тому, нову також думаю взяти Lemforder
/upload/iblock/53f/bkxp43zxf0l2osv03hnyxzcscjjzk3df/podushka_dvigatelya_ren.jpg /upload/iblock/2e4/oj1u5a801u0rjay1jk5r9uu13u0pqsvw/IMG_20250909_165004.jpg
732 Відредаговано alexei74 (2025-09-09 17:42:13)
Чому?
https://logan.in.ua/forum/topic9606-nuz … izhka.html
мои страдания п.8
П.С. на тот момент была такая ситуация и судя по стонам у наших нехороших соседей, это был не единичный случай с Лемфердером, возможно сейчас все изменилось, но осадочек остался. Себе поставил 05093 METALCAUCHO.
У мене ще рідна, міряв штангелем - вийшло 29 мм. Я б сказав, якщо руля не трясе (вібрація) то не міняв би. Хоча кажуть що їх треба міняти всі три одночасно.
734 Відредаговано igorsh88 (2025-09-15 11:59:04)
КПП ЗАМІНА МАСТИЛА
/upload/iblock/363/r1z9ghd812ngi3am07ipv46piq8uavt2/IMG_20250913_114333.jpg
100 тис. км. і 5 років на старому доброму ELF NFJ 75W-80 но його вже ніде не купиш  dntknw
/upload/iblock/0f0/2619ykyi7jbhfaso76unja2f2ns8gjkx/IMG_20250913_122324.jpg /upload/iblock/8a0/cb2lt51w8vqa6hamvt7rlr75c05y5xt9/IMG_20250913_122623_1.jpg
Перейшов на аналог Valvoline gear oil 75w 80 gl 4 (868215) заливши 2.5 л, замінив ущільнювач пробки (Masster-у не кажіть  vissla ) особливих змін не відчув.
/upload/iblock/220/myghqrj1ppk2h4dg2jjfauvxas4xtamy/IMG_20250913_124041.jpg /upload/iblock/907/0u9vdksou4152w9wv2us9ymvrgc0goxw/IMG_20250913_123914.jpg /upload/iblock/80b/8qyvzytt8a8dzo311a05p47nlv7oly1t/IMG_20250913_123037.jpg
Я все бачу )))
736 Відредаговано Aprox (2025-09-15 08:41:15)
Я отаке купив, хіба це не воно?
https://i.ibb.co/JwfqdxSG/6767.jpg
Міняв би зимою в мороз, то зміни були б відчутніші. Я в себе вирішив поміняти коли з приходом холодів в один момент при включенні першої передачі інколи відчува хруст, тобто не спрацьовував синхронізатор, спочатку були підозри на гідравлічне щеплення, але потім згадав що такі приколи з синхронізаторами на славуті були коли масло випрацьовувало свій ресурс, і після заміни все приходило в норму. Тут вийшло так само, після заміни масла все прийшло в норму.
ну если верить желтому кружку в левом верхнем углу этикетки, то ОНО подходит для коробок куда ранее заливали масло типа NFJ и NFP 75w80 и теперь имеет индекс NFX, о чем можно прочитать на оф.сайте эльфа.
Хотя ранее эльф утверждал примерно так  *Elf Tranself NFP 75w-80  представляет собой масло, относящееся к классу SHP. Разработан для применения с КПП, работа которых происходит в условиях высоких нагрузок. В частности, речь идет о коробках передач Рено, относящихся к классу Р.* т.е это  коробки  РК1 РК5 РК6 и прочие
примерно такой же смысл был и для масла  Elf Tranself NFJ 75w-80  * Предназначена для применения с коробками передач, оборудованными системами ручного переключения. При этом предусматривается, что функционирование агрегатов связано с предельно высокими нагрузками.* Было рекомендовано заливать в коробки типа Jxx, т.е. JH1 JH3 JR5 как на наших логанах и прочие КПП у которых первая буква J.
Если совсем просто, для разного типа коробок свой тип масла, т.к. свойства и масел отличаются, как и сами кпп. А теперь Эльф утверждает *ELF Tranself NFX 75W — сучасна трансмісійна олива, яка замінила зняті з виробництва ELF Tranself NFJ та NFP 75W-80, повністю відтворюючи їхні сфери застосування.* И тут возникаю вопросы - как  одно масло может одинаково хорошо работать в разных типах КПП (если ранее требовалось для каждой своё). По логике - если новое NFX полностью соответствует NFJ, то оно никак не заменит NFP и наоборот. Если же NFX это что то среднее между NFJ и NFP, то о полноценной замене вообще речь идти не может. Вот если коротко не вдаваясь в подробности))).
А дальше каждый решает сам что ему заливать в свою коробку, то ли новое NFX или искать полный аналог NFJ.
То всьо комерція щоби розводити лохів на гроші.  big_smile
Треба просто лити відпрацьоване з тепловоза або з комбайна! )))
741 Відредаговано igorsh88 (Вчора 08:31:21)
FM РАДІО ПІДСИЛЮВАЧ
https://logan.in.ua/upload/iblock/9c0/dd0ucq33n1tvuvpvolz9vps3pbujel9e/IMG_20250919_072614.jpg
Загалом - не допомогло, як ловило 1-2 станції за містом так і ловить. Зміни мінімальні. Заявлені характеристики по АЧХ не відповідають дійсності
/upload/iblock/3b8/vsh0b8psh4uwfo5i21nvdxfa2ssdxs2w/IMG_20250911_143631.jpg /upload/iblock/d9f/nh46c5gsw5x35bwndv8zf5mpx33toq4e/IMG_20250911_142640.jpg
Поки ліпив, щось коротнув - спалив магнітолу, довелось міняти мікросхему живлення. Не любить український виробник Китай.
/upload/iblock/48c/grs06nehgy0w59szvj498v6uju2oopv4/IMG_20250913_133831.jpg /upload/iblock/a43/qur7kiamc67ikl4f15qiknm4ic227f7n/IMG_20250917_131325.jpg
Література: Підсилювач FM сигналів FM-017
Ціна:
240 грн підсилювач
100 грн ремонт магнітоли.
Я років 15 тому до магнітоли деу брав підсилювач FM-18, то працював справно. У нас такий рель'єф, що селище знаходиться в ямі, починаєш спускатись з гори і сигнал радіостанцій що знаходяться за 40 км в обласному центрі починає пропадати, з підсилювачем почало ловити навіть з сусіднього обласного центру що знаходиться за 90 км по прямій.
Можливо справа в самій магнітолі, в мене зараз рідна форд без підсилювача 2-3 штуки ловить, а попередня деу три роки тому вже без підсилювача ловила більше 10-ти.
В магнітолі має бути настройка які станції ловити, всі чи тільки місцеві, там є вибір між DX та LOCAL, потрібно вибирати DX.
https://www.v12.com.ua/data/big/fm_018_avtousilitel.jpg
