1 Відредаговано igorsh88 (Вчора 10:36:34)
https://logan.in.ua/upload/iblock/2f9/2dkg3r1btdu7zxmu0epx4c22zdy1aohv/480_640.jpg https://logan.in.ua/upload/iblock/b46/2hlyvyygk7mg0nyk6tlb88hpo1auex6e/VAZ163-_1_.jpg  https://logan.in.ua/upload/iblock/858/51q4d6pd6mqoug6zq22rw4rua4xj3m2m/6400480-_1_.jpg https://logan.in.ua/upload/iblock/195/xo43rd2f45ae2t2vwh3k9fdvkyzv79oi/elektrosxemi_renault_logan_rul_600x800.jpg https://logan.in.ua/upload/iblock/6a1/c033nkp9y65qp6ng7dlypwk8xcydshmk/Bezymyannyy.jpg https://logan.in.ua/upload/iblock/c5c/kjj8o9vlqn1jy4frpa0megbmzqqsvlej/Remont_Largus_1.jpg https://logan.in.ua/upload/iblock/b25/9a2qt142flwvdr7wqixqmva8ns1yl4c4/IMG_20230519_210157-_1_.jpg https://logan.in.ua/upload/iblock/452/kwzpr98u0w17g8966120nvd65iqh0pj3/IMG_20230519_213929.jpg https://logan.in.ua/upload/iblock/881/sshfora44bhsvx3vnaoy0gmghvd8gjzd/IMG_20230914_172105.jpg https://logan.in.ua/upload/iblock/961/qq6q4gfoa10am2oiepcb7znodezl1bhk/IMG_20230925_162024.jpg   https://logan.in.ua/upload/iblock/4e9/gynrgsstp906kkdbylitn0i3gxdsda1m/imgonline_com_ua_Resize_ntSsg3czHQ.jpg https://logan.in.ua/upload/iblock/40e/6fhe9dhwrmyqlbj2ocfalpcduf9ek1fa/elektronne-kerivnitstvo.jpg https://logan.in.ua/upload/iblock/e5e/holph3yxjjs704kcfu5yl5teq6v5o5bb/IMG_20231031_072431.jpg https://logan.in.ua/upload/iblock/c53/bwr6mzwwcochmmo6e84t6d1t75soe9dk/IMG_20231031_072928.jpg https://logan.in.ua/upload/iblock/c39/309rj5xqpqm1ng6525p06nc7tpn2a1wq/imgonline_com_ua_Resize_sYYs767Im6V9i2.jpg   https://logan.in.ua/upload/iblock/930/8r9s7k21hob78t1s7e3stj43i1nencva/imgonline_com_ua_Resize_G48M7NWRo6.jpg   https://logan.in.ua/upload/iblock/529/5yotxcj2zw8aza3cqnrajnttz0y7fszd/imgonline_com_ua_Resize_AIL9k68nl0Dv8k.jpg   https://logan.in.ua/upload/iblock/689/5mtf37g2ttjmj540al3znyu2g4qzjhkm/imgonline_com_ua_Resize_ef9xKA6hPI20.jpg https://logan.in.ua/upload/iblock/1db/6jscetdf9w8vzzpzxlwuo8ijpjcuz3vr/Bez-imeni.jpg https://logan.in.ua/upload/iblock/972/knknql8kgeqaxcj2lr8rundtjidk02jn/16583055-_1_.jpeg https://logan.in.ua/upload/iblock/50e/21vm4v86bmt06gvu8dg0f2pmvbtpvy7y/imgonline_com_ua_Resize_kIxMxOj9jQZwpo.jpg
751 Відредаговано igorsh88 (2025-10-13 21:06:20)
alexei74 написав:
наконечники поменяли, а рулевые тяги нет?
https://logan.in.ua/upload/iblock/540/e0i33cbl8mlg51aw3j00eb3w029xu0he/01046482-_1_.jpg
Був впевнений, що тяга є складовою рейки і не міняється окремо  dntknw виявляється ні  fool  На майбутнє знатиму, номер на фото 7, номер по каталогу 6001550441.
752 Відредаговано igorsh88 (2025-11-19 08:37:00)
SANDERO. ТО ПЕРЕДНІХ КОЛОДОК
/upload/iblock/53c/2r7ums8okd40eyx2l7p30gwuum92xxrp/1763526441806.jpg /upload/iblock/7aa/arh7o7nqgivyb6siplv1elo9c0t7qn3s/1763526441825.jpg
Індикатор зносу на межі но міняти не став - до літа ще походять, товщина фрикційної накладки 9 мм.
/upload/iblock/39c/mdlyeqi8tdjs1wdoiu1z24cbib84f8a3/IMG_20251118_115228.jpg
Розібрав, почистив, змастив. Скоба 105 Нм, напрямні 34 Нм.
/upload/iblock/44a/jsfe67g10armx0f3pbf90ffyrdv7awco/1763526441850.jpg /upload/iblock/ced/czu9j5cmr30v90ol8jady38nk23fnsub/1763526441843.jpg
і хутко втік в хату - холод собачий.
/upload/iblock/314/7lw4xos66wjkkef09sr6gg52l1rw3o6p/1763526441775.jpg
P.S. Нові колодки в запасі, чекають літа.
/upload/iblock/497/krwx0xy6a32mzhoyr52q5jfexrn98bfa/1763526441785.jpg
Так то не індикатор зносу. Допустима товщина фрикційних накладок до 2 мм.
754 Відредаговано vlad5229 (2025-11-19 12:43:29)
Індикатор зносу то напевне бляшка на першій фотці, при торканні до диску має скрипіти.
755 Відредаговано Grim (2025-11-19 17:25:52)
LOGAN. ТО ПЕРЕДНІХ КОЛОДОК
/upload/iblock/741/x2kdvw28nsbe2bdg52s3b18imzh6d8gu/IMG_20251120_094613.jpg /upload/iblock/432/z0jbg3lv8zx87zhfpj14z17gg4genwpx/IMG_20251120_095047.jpg
Змінюючи тапці на зиму провів ТО передніх колодок. Розібрано, почищено, змащено, зібрано.
/upload/iblock/be7/j1v3lsc1zf82shqr4tfen1mqfp8jfyjd/IMG_20251120_092907.jpg /upload/iblock/bc9/lqo5g7ft6wngzrnlzc8p7az2bb9b6n9w/IMG_20251120_084512.jpg /upload/iblock/6a4/6c1zwl76r152mqm85qkn3zp58w81o74b/IMG_20251120_091944.jpg
До мене дійшло, що проріз в колодках то не індикатор зносу  fool  тут її взагалі нема но товщина фрикційної накладки 10 мм. Тормозних диск пройшов 100 тис. км.
/upload/iblock/38e/9uv3fpo8qd7h2sydcycjo8vxc22ue2se/IMG_20251120_092938.jpg /upload/iblock/c08/vhcs814y21c2jl1sjx0iqkyhv5kqeps6/IMG_20251120_081605.jpg /upload/iblock/7e7/6lrc79llhwo0aj9dqxe6gcifh83sh74b/IMG_20251120_081610.jpg
Додатково полагодив кріплення термозахисту над глушником.
/upload/iblock/2f3/7427jbqjclgfqwrs5tnjtfs34tqxpl4y/IMG_20251120_102103.jpg
Когда накладка имеет удлинённую форму по середине тормозного материала делается разрез, делящий накладку на две части, а на больших колодках и больше. Разрез делается глубокий – почти до каркаса. Цель такого разреза снизить напряжённость, возникающую в материале, и тем самым предотвратить образование трещин между каркасом и фрикционным материалом.
На практике есть опыт изготовления одинаковых колодок и с пазом (пропилом) и без него. После эксплуатационных испытаний на накладке без паза всегда появляется трещина примерно там, где должен быть паз. Т.е паз защищает материал от растрескивания, перераспределяя температурные и механические напряжения материала.
Кроме того, паз помогает удалять продукты трения и попавшие с дороги загрязнения из зоны контакта, что также видно на изношенных накладках. Например, на накладке до паза есть глубокая канавка от пыли, а в пазе она прерывается. Это повышает износостойкость накладки.
758 Відредаговано igorsh88 (2025-12-14 16:13:33)
LOGAN. ТО
/upload/iblock/361/dzbsoewha4kznapoc87i1cggs0m529co/IMG_20251214_091734.jpg
Замінено
1. Мастило Elf evolution 900 sxr 5w-40
/upload/iblock/8b2/tfm9oo6kagie43ktlgjatpbb58g5r2pn/IMG_20251214_083010.jpg /upload/iblock/ef2/ll1sb8t81kvho6attdh7hk64fsvvrhfl/IMG_20251214_094922.jpg
Злив - 4 л
Залив - 4.5 л
2. Фільтр мастила Purflux LS932
/upload/iblock/794/t91msds6hscqccfhp4ssnavi0q5jc9de/IMG_20251214_085719.jpg
3. Фільтр повітря Renault 8200431051
/upload/iblock/733/5x3geoodacemfngz35tdc5hnbqigsnq2/IMG_20251214_084318.jpg /upload/iblock/c1d/r02ijtc08pazze3xgf9czw9bf8ihv4j8/IMG_20251214_084703.jpg
4. Шайбу зливної пробки Erling 834.823
/upload/iblock/2ae/ym7tw44e3r43vittiaxwdtvy5xpus04q/IMG_20251214_091204.jpg
Та розблокуйте вже того Masster-а - йому сподобається.
5. Свічки Renault 7700500155
/upload/iblock/e77/zwqe4u02c5248srgmhop22i4go01v4fd/IMG_20251214_113253.jpg
Момент затяжки - 30 Нм.
759 Відредаговано igorsh88 (2025-12-19 21:56:31)
ГБО BRC, ТО
На газу: 85 тис.км. / 3 роки
Розхід: 8-9 л/100 км
Виконано:
1. Заміну фільтра рідкої фази
Інтервал: 15 тис. км / 4 міс
Час: ~20 хв
Вартість: 1500 грн.
Місце: Київ, Оболонь, BRC
АЗС: Avantage7
Газ: 35 грн/л
Спасибо сказали: Sivil1
760 Відредаговано igorsh88 (2026-01-07 11:23:12)
NANO 20
/upload/iblock/2d0/dchlynpz8o0rm8a7zxq33ij99cfq30vv/IMG_20260106_075103.jpg
Намагаючись зарядити старенький акум китайською зарядкою помітив, що вона недозаряджає його. Аналогічна ситуація спостерігається і в джерелах безперебійного живлення з вбудованою зарядкою типу Volt Polska. Алгоритм яких передбачає тривалий, після основного заряду, подальший поступовий дозаряд малим струмом протягом тижнів, що в наших реаліях неможливо.
Придбав зарядний пристрій українського виробника Nano 20 що має як автоматичний так і ручний режими заряду, що дасть змогу самостійно контролювати процес заряду.
/upload/iblock/3f8/j4oiugpkamroxd5ocr3w20h6gonwnajy/IMG_20260106_073813.jpg /upload/iblock/e0f/1ojobzz9j39k3nw35mdejrjs36qale3j/IMG_20260106_073835.jpg /upload/iblock/b51/60x2kl1otkrjbbv9ei18e82r0w89ttgx/IMG_20260106_073856.jpg /upload/iblock/3f7/s0tp0wgp8bp9jmhsp6lkuw47yr4t7pxy/IMG_20260106_073905.jpg
P.S.
Додатково придбав ватметр для контролю споживання, но китайці зажали встановити підсвітку екрана та акумулятор для збереження даних - доробив самостійно.
/upload/iblock/5ca/5gkwsw73lutovybifcjg1bkg1usjc14a/IMG_20251230_140243.jpg /upload/iblock/a7e/l3zp5852z2jaqyfxonb21m3no5yk2eme/IMG_20251230_141253.jpg
761
Щоб заживити  пічку,при відключеннях,теж грався з подібними зарядками,але вони не вивозять,перегріваються. Вже запущену пічку недозаряджені АКБ ще яко-тако тягнуть,а запуститися на посажених вже не вдавалося.
/upload/iblock/152/3lupoloiu0jsgubeq9sjtn41klxiz3n7/photo_2026_01_07_10_35_27.jpg
Тому довелося відновити такого совкового монстра. Був позичках спалили при запуску. Валявся років з 20 по горищах.
/upload/iblock/f9c/rqbtx0s7u2063lf1ih884znk7f7g3dp0/photo_2026_01_07_10_35_27-_2_.jpg
Цього апарата вистачає на все.
Погуглив  - солідний апарат. Правда ,ціна теж солідна...
763 Відредаговано igorsh88 (2026-03-15 21:55:18)
ЗАМІНА ГЛУШНИКА
/upload/iblock/86a/l3ex7swujt8qzmojy4d5dy7wl947apen/IMG_20260315_142048.jpg /upload/iblock/627/fpy7aonbezc66ehw1ah336pt6ufiu9m5/IMG_20260315_142033.jpg
Встановлений 4 роки тому глушник від Bosal прогнив до дир пройшовши 100 тис. км. Замінив на такий самий.
/upload/iblock/00e/90wyb5n1pznfok97ux40lcj3kdhgpdoq/IMG_20260308_141502.jpg /upload/iblock/cb0/tfpa5c841ulll2mui8w0mmf2vvs8iy4t/IMG_20260315_140401.jpg /upload/iblock/a0b/8snsozppu3hbz7mbtmuvfvy3sawgxtud/IMG_20260315_140354.jpg /upload/iblock/96f/md2ebveb7lferre5hbik41oss221ihox/IMG_20260308_141710.jpg
Матеріали:
1. Глушник Bosal 200-005, ціна 1558 грн
2. Хомут FA1 911-945, ціна 86 грн, 2 шт
3. Герметик вихлопної системи Liqui Moly був в наявності
Маленький отвір треба зробити в найнижчій точці банки щоби конденсат стікав.
765 Відредаговано igorsh88 (2026-03-16 10:34:27)
КОНДИЦІОНЕР. ПОШУК ВИТОКУ
/upload/iblock/20e/cbeu5mgnm2kzg2w507nnv9rrooao5dbu/IMG_20260316_084801.jpg
На Sandero, замінивши радіатор кондиціонера та заправивши фреоном, через місяць виявив, що кондиціонер не запустився.
Причина - відсутність тиску в системі. Датчик показав абсолютний нуль Бар. Здивований такою обставиною вирішив спершу перевірити сам датчик тиску. Підкинувши до нього змінний резистор та покрутивши побачив, що він живий. "Накрутивши" 5 Бар навіть зміг запустити кондиціонер. Тобто датчик справний. І дійсно, натиснувши на заправочний клапан ніякого пшику не було - фреон був відсутній.
/upload/iblock/eab/hcfe0csu95javaqpbhqip320h2il1vil/IMG_20250923_085043.jpg /upload/iblock/8cf/w76xyc8hikoxkxw6sedecggkkzgbiivb/IMG_20250923_210112.jpg /upload/iblock/dac/ruosxvbsexvn8wxbpy0e9us87kj62v0z/Screenshot_2025_09_23_21_02_42_653_org.prowl.torque.jpg
Придбав спеціальний клапан та задув з компресора в систему 6 Бар. Помазюкавши все пінкою витоку також не знайшов. Хоча тиск падав стабільно зі швидкістю 1 Бар/5 хв
/upload/iblock/828/lwh7w9p71at3622t38pl2cfijkwlts01/IMG_20250927_124952.jpg /upload/iblock/9da/yc5ltbzavxvwkahj367uyrrf0z81entf/IMG_20250928_155403.jpg /upload/iblock/f9c/9v2eciq8sft9igbehk1t584nr7slpmad/IMG_20250928_155545.jpg /upload/iblock/622/7ch4okrajjr7zuhxxwj5zyx5j6wd0hiz/IMG_20250928_161829.jpg /upload/iblock/aa0/f7328f3m5a4xpsz7f89xijnfe11f9nwd/IMG_20250928_161727.jpg /upload/iblock/db5/xy83sr2nog9cfjo47airtrtxv1qzu3lr/IMG_20250928_161502.jpg
Далі, вирішив перевірити недавно встановлений новий радіатор кондиціонера. Відєднавши його та кинувши перемичку, задув повітря повторно. Однак діло не в радіаторі, тиск так само падав. Приєднав його назад.
/upload/iblock/990/hpj66gzabi0387o0fgz560pkf4oi4s5c/IMG_20250928_182111.jpg
Далі на черзі радіатор, що в салоні. Аналогічно, відєднав, кинув перемичку і задув 5 Бар. І, О чудо ! Тиск тримається. Лишив на ніч, періодично знімаючи покази та температуру:
5 Бар, 16 градусів
4.8 Бар, 9 градусів
4.6 Бар, -2 градусів.
/upload/iblock/aa4/slwq131111po98d02w3z5zce2apu43pv/IMG_20260315_150538.jpg /upload/iblock/84e/4fzvys6a7fpnbsohf1tq05o3o55m1agg/IMG_20260315_150542.jpg /upload/iblock/041/za76aihota2xn43i69zf98qczo27x0ft/IMG_20260315_150550.jpg
Згідно, закону ідеального газу в закритій системі відношення тиску до температури повинно бути сталою величиною. Переводимо градуси Целсія в градуси Кельвіна та враховуючи, що датчик показує не абсолютний тиск додаємо до його показу ще 1 Бар. Маємо:
P=5+1=6 Бар, T=16+273=289 К, P/T=6/289≈0.0207
P=4.8+1=5.8 Бар, T=9+273=282 К, P/T=5.8/282≈0.0205
P=4.6+1=5.6 Бар, T=-2+273=275 К, P/T=5.6/275≈0.0203
Тобто, з точністю до ±1% система герметична.
/upload/iblock/86f/zj0nnuctf3hyw5x69wkjtfoyeb0vgcqr/Screenshot_2026_03_15_16_11_25_756_org.prowl.torque.jpg /upload/iblock/151/l4mukkel0so4b6ny24eub6dp1norw301/Screenshot_2026_03_15_18_35_33_262_org.prowl.torque.jpg /upload/iblock/d8f/zl3o53gcjupjd79n3iy3ei3upduxos3d/Screenshot_2026_03_16_05_19_59_915_org.prowl.torque.jpg
Висновок: необхідна заміна радіатора кондиціонера, що в салоні. То й не дивно, враховуючи, що фільтр салону відсутній, думаю йому точно хана. Попереду розборка торпеди та його заміна, а також врізка салонного фільтра.
/upload/iblock/e2e/khr79nc5v2vwmc4qw10oa62wt9xhiusq/IMG_20260315_151150.jpg
Після такої процедури напевне доведеться осушувач міняти.
767 Відредаговано igorsh88 (2026-03-16 12:36:45)
Отвір присутній но не в найнижчій точці
/upload/iblock/16d/5022gj4u9xaf0ne7b1yhjsau8l8vvkfv/IMG_20260316_094714.jpg /upload/iblock/870/47rbhwbjp4lmlp4zfnut30xtgt22mxn3/IMG_20260316_094656.jpg
768 Відредаговано igorsh88 (2026-03-16 10:51:52)
Не допоможе - згниє всеодно. Просто розхідний матеріал.
Приєднуюсь. Отвір десь 4мм диаметром. В мене давно просвердлений.
770 Відредаговано igorsh88 (2026-03-20 21:34:23)
LOGAN. ДОЗАПРАВКА КОНДИЦІОНЕРА
/upload/iblock/149/su3eu1u1dnej9r9ihbj6lz0zluzoi3q1/IMG_20260318_140033.jpg
Минуло три роки з останньої заправки. Тиск в системі знизився до 2 Бар та інколи перестав запускатися. Загалом пропало мінус 130 грам фреону. Дозаправили, тепер до літа готов.
/upload/iblock/6da/x0f43set78zp9yus7bz80hcoi709asaz/IMG_20260318_135013.jpg /upload/iblock/ee9/tgyq53j16rlbfrl356pq92kzo29yazgm/IMG_20260318_141444.jpg
Вартість: 700 грн
771 Відредаговано grapes (2026-03-30 21:53:12)
Чим дозаправляли ?
R134 ?
772 Відредаговано igorsh88 (Вчора 20:57:03)
LOGAN. ЗАМІНА ЗАПРАВНИХ КЛАПАНІВ КОНДИЦІОНЕРА
/upload/iblock/c64/zt18rd9hvl6pb0cxsxunyn4wi8v6p9zx/IMG_20260402_101045.jpg
Не довго поїздів. Тиск впав, кондиціонер не запустився. Причина - пропускав заправний клапан кондиціонера. Замінив на оригінал.
Матеріали:
Заправний клапан кондиціонера 7701205920 1333 грн
grapes написав:
Чим дозаправляли ?
R134 ?
/upload/iblock/ea2/5kjkzjh4i2n3mt225d4jm2g2kla01sku/IMG_20260402_093336.jpg
Заправочний об'єм моєї системи:
475 грам 1,1,1,2-Тетрафторетана (R134a)
